mysql > data>php>xml>flash question please
COW Forums : Adobe Flash
Ryan Summey
on Jun 28, 2008 at 2:07:47 am
im making flash thats going to show events for the bars/clubs around the area i have
id, bar, time_date, info fields in mysql db
all is working great
http://www.wncnightlife.com/event.html
so basicly the php logs on grabs the mysql db then codes it into xml for flash to read...
my issue is i want it to be AS3 not 2 and anyway to convert my AS2 code to 3
this is the code
var theXML:XML = new XML ();
theXML.ignoreWhite = true;
theXML.onLoad = function() {
var nodes = this.firstChild.childNodes
for(i=0;i theList.addItem(nodes[i].firstChild.nodeValue,i);
theXML.load("http://www.wncnightlife.com/events.php");
thank you for your time
-summey
Pieter Helsen
Re: mysql > data>php>xml>flash question please
on Jun 28, 2008 at 10:21:35 am
This should do it.
var loader:URLLoader = new URLLoader();
loader.addEventListener(Event.COMPLETE, loadXML);
loader.load(new URLRequest(“http://www.wncnightlife.com/events.php”));
function loadXML(e:Event):void
xml = new XML(e.target.data);
trace(xml);
Kind regards,
Pieter
Ryan Summey
on Jun 28, 2008 at 5:12:39 pm
Thank you for your response. I tried the code you gave me and it returned it with this
line 13 1120: Access of undefined property xml.
line 15 1120: Access of undefined property xml.
trace(xml);
-summey
Sher Ali
on Jun 28, 2008 at 6:35:14 pm
that is because xml is declared anywhere. Either declare the xml at the top to make it accessible by all the code or inside the event handler. To make it accessible by all code you can do this:
var xml:XML = new XML();
xml.ignoreWhitespace = true;
loader.load(new URLRequest("http://www.wncnightlife.com/events.php"));
trace(xml);
BTW you should check this out:
http://www.flashden.net/item/dynamic-xml-events-calendar/12667?ref=SaafiDes...
Sher Ali
Flash & Flex Developer
website: http://www.webeyestudio.com
blog: http://www.kabulinteractive.com/blog
My FlashDen Portfolio
Ryan Summey
on Jun 28, 2008 at 7:12:50 pm
Thank you for the response!
i checked that link and yes that calender would be awesome but its 20 bucks hahah i don't have 20 bucks to spend on that haah i would love to create that. that was my first idea that i had but i was reading up on how to make a calender in flash and didnt find much.
i may suck it up and by that.... but whats the fun in tat i want to learn how to do that
Ryan Summey
on Jun 28, 2008 at 8:19:02 pm
well i just made you richer i got the event calendar you made :)
i love it its exactly what i need but i just sorta puts a downer on me i wanna learn how this thing works and not take the wasy away out ...
thanks for your time and good work im sure ill have questions about this
-Ryan
Opeyemi Ogundimu
on Apr 7, 2009 at 12:13:16 am
Hello Ryan,
I'm an intermediate flash user wanting know how it is possible to retrieve xml data and display it in Flash.
My problem is with the Actionscript 2.0. i have the following code
var nodes = this.firstChild.childNodes;
for(i=0;i<nodes.length;i++){
theXML.load("../../../get_data.php");
but each time i run the movie nothing happens. No errors and no data. Please put me on track. All help would be muchly appreciated.
Yemi
