Quicktime Errors
COW Forums : Adobe Flash
jimmy stewart
Quicktime Errors
on Jun 21, 2008 at 6:33:30 pm
i made a simple animation that i would like to import into final cut pro. ive tried two separate ways to make a quicktime out of flash and neither work. one, i exported through publisher setting and i get the following error: "quicktime does not support Adobe Flash tracks beyond flash version 5." i tried lowering the publisher settings to flash 4 and 5 and still the same error. two, file - export movie - select quicktime format....and it says "recording flash content" and the loader just stops. the flash files is only 30 frames. im using cs3
help! thanks,
Pieter Helsen
Re: Quicktime Errors
on Jun 21, 2008 at 6:45:13 pm
So I assume you've read this troubleshooting report? :)
This might be a bug... But if you can, place your .fla file online and I will have a look at it. Or, send it to me at doccie /AT gmail /DOT com
Kind regards,
© 2018 All Rights Reserved
