Simple Newbie Question???
COW Forums : Adobe Flash
Matt Abron
on Jun 16, 2008 at 5:41:24 am
Why is NOT possible to add buttons that work on lower layers inside animations....really the button seems to work... but when I try to code the instance I get... 1120: Access of undefined property OneSheet_btn.
Do all buttons have top be on the top layer?? Meaning the within the main time line...no is possible within sublayers...
Yikes, seems like it should be simple.
Thanks!!
Matt
Pieter Helsen
Re: Simple Newbie Question???
on Jun 16, 2008 at 8:04:44 am
Are you using graphic instances? Use movieclips for your animations. Graphic instances don't have a timeline to work with.
Kind regards,
Pieter
Matt Abron
on Jun 16, 2008 at 1:29:53 pm
Hmm,
Ok, I understand that. My question is if I add a button inside another MC...that lives inside another layer...
Terrence Dunlop
on Jun 27, 2008 at 9:16:49 pm
Are you working in Actionscript3? or Actionscript2? Flash CS3?
AS3 and AS2 work very differently with buttons.
