Flash Website not appearing...
COW Forums : Adobe Flash
Ryan Shovey
on Jun 11, 2008 at 5:16:34 pm
I just created a simple website in Flash. I published it as a .swf and a .html file. I uploaded those two files with the AC Javascript file to a folder on my server. I then replaced the HTML code in my index.html file with the code that was generated out of Flash. I also replaced the source file codes within the html to link to the files on my server.
My issue is that when I go to my website, it is a black page. Totally blank. I right-click on it and it says "Movie not loaded."
Any ideas as to what I can do or where I can go to figure this issue out? I am new to flash, I'm mainly an After Effects guy. I'd really appreciate a push in the right direction. Thank you.
Pieter Helsen
Re: Flash Website not appearing...
on Jun 12, 2008 at 9:01:45 am
Are you using PHP, ASP or any other server-side language? Can you give me the link to your server?
Kind regards,
© 2018 All Rights Reserved
