Updating an object on the timeline...
COW Forums : Adobe Flash
on May 27, 2008 at 11:59:08 pm
I have a graphic that's being used in an animation sequence, but I decided to change it a bit (in illustrator).
How do you update/replace the current object with an updated one so that you don't have to re-animate the new object?
I tried swapping symbols, but since it's a bitmap, it won't swap out. I tried converting to symbol, but then lost the animation somehow.
Thanks for the help
Pieter Helsen
Re: Updating an object on the timeline...
on May 28, 2008 at 6:57:02 am
Backup your bitmap in Windows Explorer, then rename the updated bitmap so that it has the same name as the old bitmap.
Then go to Flash and, in the Library, right-click your bitmap and choose Update...
Hope this helps :)
Kind regards,
© 2018 All Rights Reserved
