Text Shape Tween Problem
COW Forums : Adobe Flash
Naiche Lujan
on May 27, 2008 at 5:19:17 pm
I can't get text to shape tween. I am trying to skew it as part of a movement of the text. But the error says something like:
"Shape tweening will not occur on layers containing symbols or grouped objects"
I used to be able to do this on earlier versions of flash, but don't work with the program that often and so maybe I'm forgetting to do something.
Pieter Helsen
Re: Text Shape Tween Problem
on May 27, 2008 at 5:30:19 pm
It's been a while since I text tweened... But, don't you have to break apart the text? (Ctrl-B twice)
Kind regards,
Naiche Lujan
Re: Text Shape Tween Problem - SOLVED!
on May 27, 2008 at 5:54:58 pm
Your memory serves you well, Peter.
Thanks a lot, that did the trick!
© 2018 All Rights Reserved
