Help turning flash video file into a link!
COW Forums : Adobe Flash
Steven Lotter
on May 22, 2008 at 3:41:15 pm
Hi, I'm new to Flash. I was given the task of creating a Flash ad that would link to a website. I created the animation (a series of dissolves between 3 JPGs) in After Effects and exported as both a .flv and a .swf. I've tried experimenting in Flash to see if I could do this on my own, but to no avail. I need help. I know my situation is different because I didn't create the animation using Flash. All I want to be able do is turn this 15 second looping clip into a hyperlink. Could someone lend some advice?
Pieter Helsen
Re: Help turning flash video file into a link!
on May 23, 2008 at 8:24:33 pm
Open a new Actionscript 2 file.
Import the swf file into flash via File > Import > Import to Stage... Select your .swf and click Open.
This will create a movieclip on your main timeline. Click on the movieclip and in the properties panel, give it an instance name (for example banner_mc)
Now create a new layer, call it actions and click on the first frame. Open up your actions panel (Windows > Actions or F9) and type the following code:
banner_mc.onRelease = function() {
getURL("myUrl.html", "_blank");
That's all there is to it :)
Kind regards,
Pieter
Christian Anderson
on Aug 4, 2008 at 7:19:51 pm
After embedding my SWF in HTML, it still appears to be unlinked to anything. I followed the instructions to a tee. Ideas?
