Scripting some kind of Listener in AS3
COW Forums : Adobe Flash
Matt Abron
on May 21, 2008 at 11:35:48 pm
First of all i am new at Flash AS3...I come from a video editing/design background so please forgive my noob'ness.
I have a flash player (Player 1) that has a XML gallery on Frame ONE of my AS3 project.
Then i have a second player (Player 2) and library associated with that player living on Frame 2...All works great!
Except...
When the user selects the standard navigation button to go to the Next category (Frame 2, Player 2) in effect Frame 2 of the main time line...The player on Frame 1 continues to play and buffer, so you can hear it under the new frame/Player 2...
What is the best approach to stop this from happening...Obviously it is distracting and taxes the bandwidth ect...
////Here is my FLV handling Code....(Disregard the Full Screen, Auto start, ect... Functionality)////
Code:
function playMyFlv(){
_stream.close();
if(autoStart == "true" || is_single_file == false)
//player_paused = false;
toolbar.btn_play.dispatchEvent(new Event("mouseDown"));
} else {
autoStart = "true";
if(is_single_file == true){
getSingleImage();
big_play_btn.x = bg.width/2 - big_play_btn.width/2;
big_play_btn.y = bg.height/2 - big_play_btn.height/2;
big_play_btn.visible = true;
first_run=false;
toolbar.checkPlayButton();
function onMetaData(data:Object){
first_run=false;
if(contains(single_image_holder))removeChild(single_image_holder);
_timer.start();
_duration = data.duration;
_stream.soundTransform = toolbar.videoVolume;
toolbar.btn_volume.getVolume();
//resizeVideo();
function onNetStatus(e:NetStatusEvent){
//trace(e.info.code);
//this resets the player on movie end
if(e.info.code == "NetStream.Play.Stop"){
toolbar.resetMovie(new Event("e"));
first_run=true;
toolbar.alpha = 1;
if(e.info.code == "NetStream.Play.Start"){
_video.attachNetStream(_stream);
show_buffer = true;
if(e.info.code == "NetStream.Buffer.Empty"){
show_buffer = true;
if(e.info.code == "NetStream.Buffer.Full"){
show_buffer = false;
console.appendText(e.info.code);
resizeVideo();
function onTimer(t:TimerEvent){
toolbar.showTimerProgress();
toolbar.showLoaded();
toolbar.showStats();
playerTimer();
//set timer text
function playerTimer(){
var _minutes = Math.floor(_stream.time/60);
var _seconds = Math.floor(_stream.time - (_minutes * 60));
if(_minutes < 10) _minutes = "0"+_minutes;
if(_seconds < 10) _seconds = "0"+_seconds;
var d_minutes = Math.floor(_duration/60);
var d_seconds = Math.floor(_duration - (d_minutes * 60));
if(d_minutes < 10) d_minutes = "0"+d_minutes;
if(d_seconds < 10) d_seconds = "0"+d_seconds;
toolbar.player_timer.htmlText = _minutes +":" + _seconds + " / " + d_minutes +":" + d_seconds + "";
if(show_buffer == true){
var percent = _stream.bufferLength * 100/_stream.bufferTime;
toolbar.buffer_preloader.visible = true;
toolbar.buffer_preloader.preloader.rotate_(percent);
} else {
toolbar.buffer_preloader.visible = false;
///Buffers and sizes the FLV///
function createVideoInstance(){
_video = new Video(bg.width, bg.height);
connection = new NetConnection();
connection.connect(null);
Client = new Object();
Client.onMetaData = onMetaData;
_stream = new NetStream(connection);
_stream.addEventListener(NetStatusEvent.NET_STATUS, onNetStatus);
_stream.client = Client;
_stream.bufferTime = 3;
addChild(_video);
swapChildren(_video, toolbar);
function resizeVideo(){
_video.width = _video.videoWidth;
_video.height = _video.videoHeight;
var sx:Number = 1;
var sy:Number = 1;
if(bg.width != _video.width)sx = bg.width/_video.width;
_video.width = bg.width;
_video.height = _video.height * sx;
if(resizeMode == "fitScreen"){
if(_video.width > bg.width){
if(_video.height > bg.height){
sy = bg.height/_video.height;
_video.height = bg.height;
_video.width = _video.width * sy;
} else {
if(_video.height < bg.height){
console.appendText("sx = " + sx.toString()+ " " + " sy= "+ sy.toString() + " video : "+ _video.width );
_video.x = bg.width/2 - _video.width/2;
_video.y = bg.height/2 - _video.height/2;
video_mask.width = bg.width;
video_mask.height = bg.height;
////Standard Button Navagation/////
mograph_btn.addEventListener(MouseEvent.CLICK, navigate2);
function navigate2(event)
gotoAndPlay("mograph");
Thanks for any direction you can offer...
