swap symbol and inherit properties
COW Forums : Adobe Flash
evrard blom
on May 14, 2008 at 11:35:29 am
Is it possible to swap smbol so that the swaped in symbols conserves rotation, x and y value, and scale of the previous one? If the answer is yes, how do i do that?
Thank you
evrard blom
Re: swap symbol and inherit properties
on May 14, 2008 at 12:14:09 pm
oh actually they are not symbols like mc or graphics, just bitmaps i imported in library.
Pieter Helsen
on May 14, 2008 at 8:55:43 pm
Select your bitmap. In your properties window, there should be a button labelled 'Swap...' Click that and you'll be able to swap it out for any other bitmap/symbol in your library.
Kind regards,
Pieter
