Simple: Adding pictures to a Scrollable Text Field?
COW Forums : Adobe Flash
Matt Abron
on May 8, 2008 at 10:30:17 pm
Thanks for you time,
I am using the UI Scroll Component and I have no problem setting that up with text, but I would like to add some thumbnail images to the text that scroll with the descriptions.
How do I do this?
Thanks for your time!
Matt
Pieter Helsen
Re: Simple: Adding pictures to a Scrollable Text Field?
on May 13, 2008 at 6:59:06 pm
Make sure to set your textfield to render as HTML and then use the HTML IMG-tag
However. This only works with Flash 7 and up.
Kind regards,
Pieter
Matt Abron
on May 13, 2008 at 9:15:45 pm
Thanks Pieter,
I have been reading about how buggy this can be and I have simply have had no success.
Do you know of a simple step by step workflow/tutorial that is online?
I need to add multiple pixs next to specific text...a bio scroll window...
Thanks again for your time....really!
Kindly,
matt
