AIR won't write file!
COW Forums : Adobe Flash
Benjamin Tattersley
on Apr 19, 2008 at 12:14:40 pm
Im having a problem with my air app. It reads in an XML file in the same directory using the url loader method, then when closed uses a FileStream to update the file, (it points to the applicationDirectory) however when i test the movie and close it to update the file, i get the following error message:
SecurityError: fileWriteResource
at runtime::SecurityManager$/checkPrivilegeForCaller()
at flash.filesystem::FileStream/open()
at gofly_brand_task_manager_fla::MainTimeline/saver()
if it helps, drop me an email at benjamin.tattersley@ntlworld.com and i will send you the source files.
Quick response would be appreciated as the release date is very near!
once again, much appreciated
Benjamin Tattersley
