Dynamic Text From an external file issues with % character
COW Forums : Adobe Flash
Andrew Stone
on Mar 26, 2008 at 12:59:20 pm
Hello,
I have a dynamic text box that loads the text from an external txt file. I have it so that html is enabled so that I can make links, change font size, etc. However it reads the % sign as code I believe and just puts in a space. I looked up the html entities I believe its called, and it was % however that did not work. Any suggestions for me?
http://www.somethingmisleading.com
Sean Hellwig
Re: Dynamic Text From an external file issues with % character
on Mar 26, 2008 at 6:41:40 pm
Try using the unicode symbol for the percent sign. see the link below and use the HTML Entity (hex). Hope this helps
http://www.fileformat.info/info/unicode/char/0025/index.htm
"I'm in the business of making sh*t happen"
Andrew Stone
on Mar 30, 2008 at 4:28:19 am
Sean,
I appreciate your response. Sorry for the delay in replying, I am working on the site on weekends for a friend.
I tried the hex code "%" and it did not work. I am beginning to wonder if I am doing it incorrectly? I just paste it in its entirety in the txt file.
Any other suggestions?
Andrew Stone
on Mar 30, 2008 at 5:05:15 am
I did some more googling and found this and thought it might be helpful to other dynamic text external file users out there...
http://kb.adobe.com/selfservice/viewContent.do?externalId=tn_14143&sliceId=...
Its apparently %25 for flash... there is a huge list that is quite helpful.
