clickTAG
COW Forums : Adobe Flash
Taleea Starr
clickTAG
on Mar 25, 2008 at 1:06:26 pm
Greetings.
I create flash advertisements for an online newspaper. The company is wanting me to do a tracking actionscript to the flash files. I have the script that I need, but I don't really understand how to use it correctly, I keep coming up with errors.
Here's what I have:
on (release) {
if (clickTAG.substr(0,5) == "http:") {
getURL(clickTAG);
I think my problem is that I'm not sure where I insert information, and what information needs to stay for functionality. I've never dealt with a clickTAG, and I'm not finding anything that explains it clearly to me on the internet. Do I leave "clickTAG" in the script, or do I replace each clickTAG instance with a URL?
If someone can leave me an actual sample (filling in data where needed), that would be extremely helpful!
Thanks in advance for any advice or suggestions.
- T.S.
Sean Hellwig
Re: clickTAG
on Mar 25, 2008 at 7:51:15 pm
Hi!
Just enter that code on any button..
where you would normally have something like
on (release){
getURL("http://whateverlink.com");
but yours would be
on (release) {
getURL(clickTAG);
YES you keep the clickTAG in the script.
It will give you errors on your end when testing it out, but will function correctly on the advertisers end. Hope this helps
"I'm in the business of making sh*t happen"
Andris McKinley
Re: clickTAG
on Sep 4, 2008 at 9:26:30 pm
What do you do with the html code?
How do you link up the clickTAG in your embed and object tags?
Sean Hellwig
Re: clickTAG
on Sep 5, 2008 at 4:45:10 am
Its been my experience that whichever ad system (DART, OpenX, etc..) you are using to serve the swf will automatically place the clickTAG variable in their embed code.
Otherwise, it can be passed via flashVars in the embed.
More info here - http://kb.adobe.com/selfservice/viewContent.do?externalId=tn_16417
Hope this helps
