Changing colour of text and adding a link
COW Forums : Adobe Flash
l_vaughan
on Jan 19, 2008 at 10:43:18 am
I am trying to create a website. I have some text in a flash text box I created. I want some of it to be green and some of it white. If I try to change the colour of highlighted text it changes all of it. Is there a way to do this?
Also - can I add a link to another area of my website (and a external site) in flash text - as clickable text?
Any help would be greatly appreciated.
Pieter Helsen
Re: Changing colour of text and adding a link
on Jan 21, 2008 at 10:21:32 am
this is possible. You have to render your text as HTML and then attach a css stylesheet.
Have a look at this article at actionscript.org.
The example also includes a clickable text link.
Kind regards,
Pieter
l_vaughan
on Jan 21, 2008 at 9:42:36 pm
wow. quite a heavy read for a complete flash / code newbie. I did kinda hope it would be simpler. i'll battle through it over the next few days. thank you!
Pieter Helsen
on Jan 21, 2008 at 9:46:28 pm
Your welcome, it's a rather advanced article indeed, but if you run into any problems, I'd be more than happy to help you out.
Kind regards,
Pieter
Sher Ali
on Jan 21, 2008 at 9:50:25 pm
Actually you have a textfield of type static and that is why when you apply a different color to selected portion it changes the color of the whole textfield.
Just change the textfield type to dynamic in the properties panel and it should work and changing the textfiedl from static to dynamic will also enable you to select a portfolio of text and then set an external url in the URL field in the properties panel.
Sher Ali
Flash & Flex Developer
kabulinteractive.com
Pieter Helsen
on Jan 21, 2008 at 9:56:07 pm
I just tried that Sher, that does seem to work as well. Didn't know that. :D
You will however, have to enable the 'Render as HTML' option on the textfield as well. Just setting it to Dynamic textfield doesn't work.
Kind regards,
Pieter
Lawrence Vaughan
on Jan 22, 2008 at 4:58:14 pm
OK, this is great guys! So how do I render text as HTML in order to do this??
Pieter Helsen
on Jan 22, 2008 at 5:39:24 pm
Make your textfield dynamic and in the Properties panel toggle on Render as HTML
Kind regards,
Pieter
l_vaughan
on Jan 22, 2008 at 8:20:43 pm
Amazing! Works like a dream Thank you!
If I add a link to some text can I browse for a page on my site, or do I have to type the address in manually? I tried this with an external site (http://www.bbc.co.uk) and it didn't work.
Am I doing something wrong?
Really sorry about this guys. I am a total flash newbie. I really appreciate this.
