Transparent FLV person over website?
COW Forums : Adobe Flash
Siggs2000
on Jan 13, 2008 at 7:19:47 pm
Hey everyone,
I am trying to figure out if it is possible to take a green screen video of a person talking and moving around, and then have hit pop up and walk around on a website that I also have built.
Maybe as some kind of an introduction when you first hit the page.
Anyone know if that's possible?
I am using a quadcore mac pro with intel 2.0 ghz.
I have final cut pro 5.1, Motion, CS3 with Flash 8, etc., FlixPro and an HDV camera.
If it's possible, I think I have the software and hardware to make it happen.
Thanks in advance to anyone that can help!
--Seth
Sean Hellwig
Re: Transparent FLV person over website?
on Jan 14, 2008 at 8:43:38 pm
This is definitely possible.. you can encode flv (flash video) with an alpha channel, create a flash swf and then in the html create a div that holds your swf movie..
A good place to get started would be to google flash video alpha channel or something like that.
"I'm in the business of making sh*t happen"
Seth Siegler
on Jan 15, 2008 at 9:21:09 pm
Awesome. Thanks Sean.
Sean Hellwig
on Jan 16, 2008 at 7:39:42 pm
Welcome.. post the results when you're done. id love to check it out!
Marvin Marshall
on Jan 30, 2008 at 2:37:17 am
You can do it in flash, just render your green screen with alpha then import the clip in flash, check with alpha and thats it see the link below of a site I am doing.
http://www.americanentrepreneurlive.com
Studiobluedigital.com
Stanley Park
on Jan 3, 2009 at 2:04:30 pm
Yes it is possible, it all depends on your ability to knock out the background (Chroma Key).
There is a much easier way to do it though.
Bloofi.com they have the solution for you.
Cheers
flashwiz
http://www.myspace.com/flashwiz
Flashmaster at http://www.myspace.com/flashwiz
Perry Lawrence
on Nov 9, 2009 at 10:53:42 pm
Here is a cool tutorial with multiple ways to get 'er done.
http://www.askmrvideo.com/public/157.cfm?sd=2
Also, this is a nice web based app on tap that allows you to manage all your walk on videos - cut and paste one line of code:
http://www.PeopleOnYourPage.com
Morgan bennett
on Jan 6, 2010 at 3:15:09 pm
I also am trying to do this.
I use premiere elements - and could upgrade to another programme if neccesary.
I can delete the background using a green screen but then don't know what to do.
Also, do you save as .flv and then export to .swf? Do you need to edit it more in flash or is it simply saving it as an .swf.
