parsing edited XML w/ AS2
COW Forums : Adobe Flash
Jeff Penano
on Jan 9, 2008 at 1:55:01 pm
So I have no idea why I'm having the problem I'm having... I have an XML object that I make changes to. Simply appending a node with a few attributes and a child node. I can trace out the changes fine and see that the XML has been correctly modified. But in my for loop when I'm trying to use the newly edited xml, the attributes come back undefined. Was just wondering if anyone had any insight as to what could be my problem.
Sean Hellwig
Re: parsing edited XML w/ AS2
on Jan 9, 2008 at 7:56:14 pm
hey, can you post your code? would be much easier to help you with your problem
"I'm in the business of making sh*t happen"
Jeff Penano
on Jan 9, 2008 at 8:52:07 pm
I figured out what was going on. I was trying to append an XML object into another XML object when I should have been using an XMLNode object. The XML object that I was editing would trace out correctly showing that the nodes had been added but since it was an XML object the attributes and everything that XMLNode supports wasn't there...
Sean Hellwig
on Jan 9, 2008 at 9:33:01 pm
thats awesome! im glad you figured it out!
