Centering a flash site???
COW Forums : Adobe Flash
macaddict
on Jan 8, 2008 at 8:52:58 pm
I created a flash site, but its not centered when I go to the site.How did I center the file so it will display evenly?
Mike Smith
Re: Centering a flash site???
on Jan 9, 2008 at 9:43:38 am
You do this with your html / css.
This http://www.w3.org/Style/Examples/007/center might help
macaddict
on Jan 9, 2008 at 4:15:08 pm
So do I paste my SWF file into my CSS using a program like Dreamweaver? Then I should be able to center it there correct.
Mike Smith
on Jan 10, 2008 at 5:42:49 pm
Whatever you are using to do your website; Dreamweaver might be overkill if all you are doing is making a page with a centered Flash file.
Any text editor would do, or there are free html / css tools like nVu (sources http://www.thefreecountry.com/webmaster/htmleditors.shtml )
or others if you need a tool.
You might want to take a look at keeping it web-standards compliant - it could be worth looking at http://www.alistapart.com/articles/flashsatay , which would give you all the code you need to cut-and-paste, as well as some insights.
KB Brown
on Jan 9, 2008 at 11:49:20 pm
In your html file that holds your flash file for display, create a div tag, aligned to the center, then place your code to embed your flash object within that div. Everything should be centered. If not, use a paragraph tag instead, in the same manner.
