export flv from Adobe Flash CS3??
COW Forums : Adobe Flash
moldvarpan
on Dec 10, 2007 at 9:38:22 am
Hello.
I'm new to Flash, so go easy on my ignorance.
I'm simply trying to export a flash sequence I created in Adobe Flash CS3 to .flv movie and there seems to be no such option! Is it really so that you cannot export a flash video from a "professional" flash editor?!!
Best regards.
Kelly Johnson
Re: export flv from Adobe Flash CS3??
on Dec 11, 2007 at 4:12:25 pm
Flash doesn't 'create' flv's... it plays them and interacts with them.
If you want to convert an entire Flash/swf file to an .flv, you need to convert the swf in some other app to an .flv or to a quicktime format and then convert that to an flv.
If you're not using too much Actionscript, you can create a quicktime file out of flash and then use the Flash Encoder to create an flv
