Do I need Flash?
COW Forums : Adobe Flash
Do I need Flash?
on Nov 10, 2007 at 9:43:25 pm
I have AE CS3. I in the export menu there is the option to export an FLV file. But I do need flash itself to use projects I create in AE for my website?
Re: Do I need Flash?
on Nov 12, 2007 at 4:23:50 pm
Not if you have DreamweaverCS3. Otherwise, you still need to produce a swf file which displays the actual flv.
Dreamweaver CS3 writes a standard swf file when you place an flv file inside a page.
Straight html code won't work.
Unless there is another way to produce an swf that I don't know about.
Although, you could export a swf from AE but if your video is longer than 10-15 seconds, it will be waaaay to big.
© 2018 All Rights Reserved
