Flash to Quicktime movie
COW Forums : Adobe Flash
Paul Holzman
on Nov 5, 2007 at 11:46:16 pm
What's the easiest way to make a QT of a Flash piece?
There are three .swfs and three flvs corresponding to each swf.
Is there a simple way to just play and capture it in a browser. Or is there a way to output from Flash to QT (clearly I'm not a Flash user!)
This was authored in Flash 8.
Thanks (for your indulgence),
Paul Fechtmeister
Re: Flash to Quicktime movie
on Nov 18, 2007 at 5:50:55 pm
I think that this is all you need.
With your version of Flash open:
Go under File > Publish Settings > Check the QuickTime (.mov) box and then decide where you want it to publish to and then publish.
Hope that helps.
© 2018 All Rights Reserved
