Dynamic.text not reading all the time..
COW Forums : Adobe Flash
on Nov 5, 2007 at 4:59:21 pm
The Calendar is working at:
but now, it doesn't when I test the fla file offline. I can't seem to figure out why the date doesn't show using textBoxInstance.text = whatever.
I've tried both with the variable box and setting it with Actionscript.
The original file was created in Flash 8 Pro and though I've now used it in FlashCS3, it's saved as an AS2.0 file.
Any ideas? File is located at:
on Nov 5, 2007 at 6:55:11 pm
Had to select "Use Device Fonts" instead of Anti-aliased for readability and it all works fine.
© 2018 All Rights Reserved
