Easy Flash Player
COW Forums : Adobe Flash
Martin Sterling
Easy Flash Player
on Oct 26, 2007 at 4:09:35 am
Is there a simple fast way to make a quick flash video player using a 3rd party program where I dont have to script buttons and a loader. It is not easy to make a flash video player on the fly.
thumbslinger
Re: Easy Flash Player
on Oct 26, 2007 at 4:48:17 am
Import FLV...choose a skin and you're done? What else do you need for a 'fast' player?
Martin Sterling
on Oct 26, 2007 at 4:53:40 am
Im new to Flash so, if you can bear with me, how do I choose skins.
thumbslinger
on Oct 26, 2007 at 4:56:36 am
When you choose to Import an FLV under file, there will be a pop-up window for the selection of skins. Choose one there.
When you publish, it will create a swf file in addition to the main swf file, that is named whatever skin you chose. That file needs to be in the same folder as the main swf file.
Also, you can search your hard drive for "mojave" and you'll find the folder that has all the skins available.
Then, it's just a matter of changing skins via the Components Inspector palette in the parameters field for skins.
