Flash video skin question
COW Forums : Adobe Flash
Wisabcon
on Oct 26, 2007 at 12:33:45 am
Flash Pro 8, Dreamweaver 8
I am trying to use one of the external skins on my Flash videos on a html page. I have no problems using the stock internal skins that are referenced in DW. It's a piece of cake to use various external skins within Flash, but I have been unable to use them in DW. I put the .swf file of a standard external Flash skin, ClearExternalAll.swf, into the appropriate DW program folder and it shows up as an option in DW along with all the standard internals skins. The skin (as well as FLVPlayer_Progressive.swf) is also in the same folder as the html file locally and it is uploaded to the same folder as the html file onto the server. However, instead of showing up and running off the server, I don't see the skin and the playback is just sort of broken and something looks like it is covering much of the Flash video. What do I need to change in DW? Or Flash?
Sample of the problem: http://www.sourcemedianetwork.com/vidskintest.html
