tweening end POP
COW Forums : Adobe Flash
Brian Dugan
tweening end POP
on Oct 1, 2007 at 11:26:28 pm
Anybody know what this might be and how to fix?
At the end of a simple motion tween of some text (just increasing size from 0 to 100%) the very last frame jumps -like it saves the last increment for a big change.
I have tried easing in and out but no luck.
I'm kinda new to flash.
CS3 on mac
Brian
Chris Lupetti
Re: tweening end POP
on Oct 1, 2007 at 11:47:57 pm
I'm not sure I totally understand what the problem is.
Make sure the the the first and last keyframe are using the same tween graphic. Also make sure none of the keyframes are grouped while the others are not. This might not be the answer but at least you'll rule it out. I have had a problem with this type of issue.
Also, don't make it go from 0 to 100%. Make it go from 5% to 100%. Whenever I went from 0 to 100 there was a problem.
I hope this is of some help.
Brian Dugan
on Oct 2, 2007 at 1:01:30 am
Thanks Chris I'll give it a try in the morning!
Brian Dugan
on Oct 2, 2007 at 3:46:35 pm
5% to 100%.
That did it! Thanks
