working with jpgs in flash
COW Forums : Adobe Flash
on Sep 24, 2007 at 4:54:47 pm
hello, i am working on a webbanner and i want to have a series of jpgs fade into eachother while having text and graphics running across them. how do i adjust the opacity of jpgs in flash? or any other technique to achieve this look. thanks.
Re: working with jpgs in flash
on Sep 24, 2007 at 5:07:42 pm
Hi there - import the jpg, drag it onto the stage, convert it into a movieclip or graphic (Select the jpg and then press F8), select the mc/graphic again and below in the Properties panel should be a dropdown list saying Color. Select Alpha and you should be able to set the opacity. :)
Kind regards,
© 2018 All Rights Reserved
