jittery elements when rendering to .mov
COW Forums : Adobe Flash
Saddler
on Sep 20, 2007 at 5:44:55 pm
I have someone exporting a Flash animation for me to use in Final Cut. We've tried exporting to different codecs, and even rendered at double resolution in hopes that it would render more accurately, but the animated elements are rendering with a jittery motion when scaled. How can this be fixed? Thanks.
Doccie
Re: jittery elements when rendering to .mov
on Sep 20, 2007 at 7:57:11 pm
My best bet would be to check if all your elements are positioned so that they are positioned on whole pixels, rather than on decimal values.
Also, are you using cacheAsBitmap or bitmaps in your document? As they tend to 'pixel-snap' which may cause animations to jitter.
Kind regards,
Pieter
