Can I loop audio and video with different lengths?
COW Forums : Adobe Flash
robert61
on Sep 20, 2007 at 4:07:45 pm
Using Flash CS3, just getting started with it. I created a slideshow that lasts 2.5 minutes and have it loop which is nice.
My audio music track is almost 3.5 minutes and I would like it to play to the end before looping. Obviously, the music does not have to sync to any particular slide event.
My problem is, the music starts playing again when the video loops, so I have 2 instances of the music overlapping. I can put a stop event at the end of the video, and then the music abruptly stops and starts over which is better.
However, I would like to simply let the 2.5 min video loop, and the 3.5 min audio loop independent of one another.
Is there an easy way to accomplish this? Do I have to use some scripting? Right now, I'm just dropping stuff on the timeline. Is there a property that lets the video and audio loop independently of each other? Or is there scripting examples of how one would handle this?
Thanks for any help you can provide.
Chris Lupetti
Re: Can I loop audio and video with different lengths?
on Sep 20, 2007 at 4:13:35 pm
Have you tried putting the audio in its own Movie Clip?
Doccie
on Sep 20, 2007 at 8:10:35 pm
This -should- do the trick. :) Let me know if it doesn't.
http://pastebin.coconut.se/?id=5594
Kind regards,
Pieter
