Variables in CS3
COW Forums : Adobe Flash
ktonkin
Variables in CS3
on Aug 16, 2007 at 4:20:43 pm
Hello
I'm trying to make a flash video player that uses a variable to know which video to play, and which caption to show.
I had it all working... but then I was told to add a "go fullscreen" button.
The player goes fullscreen if I set the content path of the video directly in the FLVplayer.
However, if I use a variable to set the content path of the video, the fullscreen won't work!
Any ideas on what I could do??
Thank you!!
this is how I'm passing the variables
player.swf?text=NFLC&video=video/NFLCpromo.flv
Doccie
Re: Variables in CS3
on Aug 23, 2007 at 6:43:36 pm
Are you using actionscript 2 or 3?
Instead of passing the variables via your url, try SWF Object.
Hope this helps.
kementzis kamkal
exit and full screen button
on Dec 21, 2007 at 8:22:38 pm
How i create full screen button in as3, and close"window" button?
thanks in advanced!!
