timeline
COW Forums : Adobe Flash
heidi Phillips
timeline
on Aug 10, 2007 at 7:00:56 pm
What is the maximum length for the timeline?
When working with a long timeline what viewing methods should be used?
heidi
Paul Fechtmeister
Re: timeline
on Aug 11, 2007 at 10:26:54 pm
I don't know if there is a max length.. but I think around 50,000 frames.
The longest timelines I've seen are when people embed video and then the timeline has content out to 5000+ frames. In general, use of the timeline should be kept to a minimum, at least I've heard. Most people recommend actionscript to due the bulk of the work with the compliment of the timeline.
When the timeline is really long you can type the frame you want to goto and that might get you there more quickly. Depending on the system very long timelines can really bog things down.
cheers,
Mike_S
Re: timeline
on Aug 13, 2007 at 10:12:32 am
Adobe lists a max of 16,000 frames here http://www.adobe.com/designcenter/aftereffects/articles/aft7at_3dflashbutto...
Don't know if this applies to all versions of Flash ...
