video player with play list
COW Forums : Adobe Flash
JD
by
on Aug 6, 2007 at 8:37:16 pm
Sorry for what is likely a newb question here.
I am a total newbie to Flash but would like to do the following:
Create a page that has an embedded Flash player (I have flowplayer downloaded and Riva free encoder so I am okay that far).
Ideally I'd have a selectable menu that would allow the user to pick which video (from either a text list or photos) they wanted to play.
Also, while I have the HTML skills to build the page, adding the flash element is beyond me. Does something like this have to be built IN flash (ie the whole page) or do I use HTML for the page and integrate some flash compenent or call to a flash file in the page.
thanks, in advance, for your patience.
JD
Paul Fechtmeister
Re: video player with play list
on Aug 11, 2007 at 9:25:04 pm
The flash can/will be embedded in the html. As far as the player a place to start might be gotoAndLearn.com try the xml video playlist.
That might get you going.
cheers,
