beginner needs help
COW Forums : Adobe Flash
beginner needs help
on Jul 18, 2007 at 5:43:05 pm
Hi all,
I am NOT a flash user. I am just trying to use the program to prepare an FLV for the web. I followed these instructions:
I understand everything but when I enter the URL into the component inspector it gives me the message "Failed to load:...". It seems as though the flash project is not linking well with my file on my server. However, when I give the component inspector a local path it works perfectly. What could be wrong?
Paul Fechtmeister
Re: beginner needs help
on Jul 25, 2007 at 10:14:58 pm
It could be a couple of things. If you want to email me some more particulars I can probably help you out. Could be path name...or browser.
on Jul 30, 2007 at 2:35:28 pm
When you enter the path it's case sensitive so make sure you have everything exactly the way it is written out. I had the same problem, also if that fails try testing a different naming convention for your file and folder. I also found that when I changed the folder and file name to a 2 character name for testing purposes I was able to load the movie right up. Might be a glitch so it's worth a try. it worked for me.
© 2018 All Rights Reserved
