animated movie clip buttons
COW Forums : Adobe Flash
wingmann13
on Jul 4, 2007 at 6:42:56 am
I am having a heck of a time creating my own animated buttons out of movie clips. I can't find a tutorial that deals with ActionScript 3, they are all older tutorials and when I try to use the actionScript it never works unless I change the AS settings to an older version of course, which I don't really want to do.
I am creating the movie clip in After Effects and importing as a png image sequence and placing it in a movie clip. I just want the movie to play on a roll-over, and fade out or stop on a roll-out.Could anyone out there help me?? Thanks
Sher Ali
Re: animated movie clip buttons
on Jul 4, 2007 at 11:59:34 am
let say you have a movieclip:
my_movieclip
and you have labeled frames inside my_movieclip like:
over
out
etc.
now add this to the keyframe(I assume that you are using the first keyframe):
my_movieclip.addEventListener(MouseEvent.ROLL_OVER,overHandler);
my_movieclip.addEventListener(MouseEvent.ROLL_OUT,outHandler);
function overHandler(event:MouseEvent):void{
event.currentTarget.gotoAndPlay("over");
function outHandler(event:MouseEvent):void{
event.currentTarget.gotoAndPlay("out");
if you have many buttons then add the following two lines for each buttone(movieclip):
button_name.addEventListener(MouseEvent.ROLL_OVER,overHandler);
button_name.addEventListener(MouseEvent.ROLL_OUT,outHandler);
Sher Ali
cow
wingmann13
movie clip buttons, hit area
on Jul 5, 2007 at 8:26:28 pm
Cool, it worked great! Thank you for the help, much appreciated. I have one more question though. My mouse arrow doesn't change to the finger pointer when I rollover my button (movie clip). Do I need more Action Script for this to happen, and is it possible to designate a hit area??
Adam
Sher Ali
Re: movie clip buttons, hit area
on Jul 5, 2007 at 9:23:44 pm
add the following line for each button:
my_movieclip.buttonMode = true;
Sher Ali
wingmann13
Hit Area is Too Big
on Jul 6, 2007 at 5:50:57 pm
So I am almost there. So far I have created a working movie clip button that incorporates a cool After Effects animation on a mouse rollover. The mouse arrow also changes to the pointer finger when highlighted which is all good, BUT;
The hit area for my button is way too large now since the movie clip has taken on the properties of a button.I tried to create another movie clip in the same layer that was the correct size to act as the
hit area that I wanted. I also made it transparent but I know my action scripting must be wrong.
Is there a way to do this or should I try a different way to customize my hit area?? The help has been much appreciated, Thanks Sher!
Here is my AS:
function overHandler(event:MouseEvent):void {
hit_btn.addEventListener(MouseEvent.ROLL_OVER,overHandler);
hit_btn.buttonMode = true;
hit_btn.visible = false;
animation_btn.hitArea = hit_btn;
