Flash Calendar
COW Forums : Adobe Flash
indyfro
Flash Calendar
on Jun 25, 2007 at 8:47:03 pm
anyone have some insight as to how I can customize the dateChooser component to reflect a firefighter shift calendar? essentially I would like each different shift day (A,B,C) to be colored differently, and repeat for the duration of the calendar.
Your help is sincerely appreciated!
Fro
thumbslinger
Re: Flash Calendar
on Jul 5, 2007 at 6:17:21 pm
What you could do is to create a separate area for info/notes and link the data from the DateChooser to new dynamic text boxes.
So, you could set up an array of the days, getDay(); and then depending on what day it is, set the color of a square box graphic or any other movie clip to a certain color. Depending on the day, the color would change.
There's a project like this in the Training from the Source for FlashMX 2004. They have an interface with a DateChooser as a small calendar in the upper right and then dynamic text boxes to the left where "Monday, July 14th, 2007" is shown.
Other than something like that, I'm not sure.
