Videos to swf, with alpha
COW Forums : Adobe Flash
Sam Vargas
on Jun 6, 2007 at 9:50:54 am
Hi there,
I want to encode video with alpha to swf. I tried two different ways.
1. I encoded to FLV with Macromedia Flash Video Encoder, with alpha turned on. Alpha worked fine in FLV. I imported it to Flash (embed into timeline), and exported it as swf.
2. Used Flix Pro, with alpha turned on.
In both case, I lost my alpha in swf. The swf plays fine in a player, but I have to use it in other flash projects, and if I import them to flash, I just get an empty movie. No alpha channel, neither RGB. Only solution is to use chroma key in flix, but it gives an awful result. Also, it would be good to automate all.
Is anyone else has this problem or just I have ? And most of all, is anyone else has a solution to it ?
© 2018 All Rights Reserved
