How do I get the best quality possible flash video for viewing on the web?
COW Forums : Adobe Flash
WSummers
on May 31, 2007 at 4:59:17 am
If any of you flash experts could help me out that would be great. I'm trying to export a quicktime out to flash and have it look as pristine as possible. The stuff I export to flash now looks ok but I see a lot of other videos that are really clear. Currently I have tried exporting out from FCP using Animation, Photo JPEG, H.264, and uncompressed 10 bit encoding codecs. And i've used size settings of 720x480, 480x360, and 360x240. I always choose de-interlace, & keep the frame rate same as the source. For keyframe placement Ive tried automatic, every 30, every 15, every 60, and every 120 frames. (There is a lot of motion in the video) And for the data rate I choose either 300 or 700 depending on what my requirements are. A friend mentioned trying sorenson squezee, i downloaded the trial version and tried it but the results were no better. But it was also the first time I tried using sorenson squezze so there might have been more options I couldve chosen. If possible i'm trying to produce a flash file with picture clarity of this: http://www.sixreasonswhy.com. Sorry for being long winded in the post, but any help anyone has to offer would be great.
Wesley
wesleysummers@mac.com
thumbslinger
Re: How do I get the best quality possible flash video for viewing on the web?
on May 31, 2007 at 1:44:46 pm
Export to full dv and then encode. Or, export to QuickTime H624 and then use the High quality settings in the Flash Encoder.
Though that url was about a western, there was some noise/grit in the video.
Also, you might be seeing video shot in HD when you see super clean video.
