export Flash 8 to FLV?
COW Forums : Adobe Flash
robert smithlee
on May 31, 2007 at 12:28:38 am
Hi there,
Is there a way to export from Flash 8 to .flv format? I need to create FLV files from Flash for progressive downloading.
More specifically, I am using flash to add titles to AVI files for delivery via flash on the web. From my past experience, this creates great titles for the web.
I am using Flash Video Encoder to import the AVI files into Flash as FLV files. Then I add the titles. Now I need to export back to FLV -- in as few steps as possible -- hopefully one.
There was a way to export to FLV using Flash MX 2004 Pro. It seems strange to me that there no longer seems to be a way to do this in Flash 8.
Also, it seems strange Flash Video Encoder imports many file formats and convert them into FLVs.... But it won't convert from SWF to FLV.
Why can't I figure out how to export from Flash 8 to FLV?
Thanks for any help.
Sher Ali
Re: export Flash 8 to FLV?
on Jun 1, 2007 at 6:30:56 am
Yes you can export from flash 8.
The Video Encoder was built-in with the Flash MX 2004, but with flash 8 the Video Encoder is a standalone application. You can find it under the Program Files from Start Menu if you are using Windows or look into the installation directory.
Sher Ali
http://www.webeyestudio.com
