Web services and components
COW Forums : Adobe Flash
on May 30, 2007 at 6:03:32 pm
I am working with the web services component to pull data and images from an .asp server so I have to use components because of binding, schema, and properties availability. Is there a way to use a loader component with onPress commands and such to trigger other components (textarea and other loaders) to activate? If so, what would the syntax look like? Thanks in advance!
© 2018 All Rights Reserved
