Can I do a "swap image" with swf files?
COW Forums : Adobe Flash
tom8gem
on May 4, 2007 at 9:14:40 pm
I can't get a JavaScript "swap image" (onmouseover/onmouseout) to work with swf files, either through hand coding or through Dreamweaver's automated coding. In Dreamweaver, the swf files are grayed out when you try to do this the way you would with regular images since they are not image files. Please advise.
Mike_S
Re: Can I do a "swap image" with swf files?
on May 5, 2007 at 9:57:11 am
If you want to change your swf in response to mouseover, could you not do that with Actionscript ..?
tom8gem
on May 5, 2007 at 5:13:17 pm
I haven't tried that yet; I'm just moving beyond the tutorial stage, and my first thought was to use JavaScript. I'm sure this is the answer I was seeking, so thank you much!
