Two animations in a html error
COW Forums : Adobe Flash
dpidesigner
on Apr 13, 2007 at 10:06:09 am
i am doing two swf animation in a html page and i am getting error in the animation itself
What happens is the first one has alpha channels and the othe are logos passing, each time the transition using alpha changes the passing logos get hickups
is there anyway to go around this or do i need to set a animation synced with the one with alpha
thanks for any help you may give me
dpidesigner
Working around graphics
Mike_S
Re: Two animations in a html error
on Apr 14, 2007 at 3:34:44 pm
I don't think I really understand what the problem is here.
Do you mean that one swf is overlaid on top of another one? If so, is there a reason to do that rather than use a single swf?
Or do you mean that changes in one swf are causing problems in another swf?
dpidesigner
on Apr 16, 2007 at 12:31:14 pm
Yes i got a html page with two swf one on top
with alpha and blur in the transtions
and one on bottom with some logos passing
each time the top swf makes a transition the logos stop their motion
my question is how can i integrate them both and not have this sort of problem where one iinfluences the other
thanks
dpidesigner
