Make Button Disappear on root timeline?
COW Forums : Adobe Flash
Chris Lupetti
on Apr 3, 2007 at 2:40:43 pm
Hello
I want to make a skip intro button disappear. This skip intro button is on the root timeline. I have another button that is two Movie Clips in. When the button from the two Movie Clips in is pressed, the Skip Intro button from the root timeline should disappear. So far nothing works.
Here is the code. Any suggestions on fixing the problem?
on (release) { this._parent.gotoAndPlay("gotoNextRoom"); __root._parent.skipButton.visible = false; //_parent._parent.skipbutton._visible = false; //_parent._visible.skipButton._visible = false; //_parent._parent.skipButton._visible = false; }
Thanks for your help.
DaveTrep
Re: Make Button Disappear on root timeline?
on Apr 4, 2007 at 8:30:13 am
Hi Chris
You didn't put an underscore on the visible and if the button is on the root timeline you just need to say _root.skipButton.
try this
on (release){
_root.skipButton._visible = false;
Hope this helps
Dave
