tracing VARs across functions
COW Forums : Adobe Flash
MadMac66
on Mar 29, 2007 at 8:48:28 pm
Hi, how do I track a variable across functions. I thought it used to be that declaring a var inside a function made it local to the function only. Is this still true. Is tere a way to find the value of a var in one function from inside another function??
many thanks
mm66
Thumbslinger
Re: tracing VARs across functions
on Apr 1, 2007 at 1:25:32 am
What are you trying to do exactly? Declaring a global variable is easier and can be manipulated via a function.
One way is to create a specific function only for one condition, and then in that function define the new value for the variable.
In an entirely different function check for a condition where that previous function is called and then reassign or get the value.
I might not be understanding the actual thing you want to do so maybe more explicit, like "I'm trying to carry a total from one action to another" or etc.
