XML and flash...
COW Forums : Adobe Flash
luthervondude
XML and flash...
on Mar 5, 2007 at 8:13:51 pm
There seems to be a 100k limit when I write to an XML file. I am writing the XML through Flash as a string. Anyone else have this problem? I need to write about 8000 records which is well over 100k. I am also using Zinc...
Help would be appreciated.
grafxflow
Re: XML and flash...
on Mar 5, 2007 at 9:10:31 pm
Why so many records (8000)?
I had this problem which caused flash to slow down or freeze. The way around it for me was to use mysql to store the data on the server, and send the data is sessions.
grafxflow
luthervondude
on Mar 7, 2007 at 2:22:06 pm
Yeah, I ended up sending the bytes to XML in groups... that worked.
