button to run script, pause, then run again ?
COW Forums : Adobe Flash
Andy Stokes
on Feb 24, 2007 at 4:22:53 am
Hi all,
I have some actionscript i'm using in a dynamic pageflip movie . Currently I have a button that when selected will run this code to flip the pages:-
nextBtn.onRelease = function() {
var nextPage = _parent.offsetPages(_parent.page+2,_parent.removedPages);
if(nextPage<=_parent.offsetPages(_parent.maxpage,_parent.removedPages)) _parent.gotoPage(nextPage);
How might I build a button that when selected will run this code, pause 3 seconds then run again. Ideally i'd like to make this a toggle button so when clicked once will start the loop, then disable when clicked again.
Any help would be greatly appreciated as i'm fairly new to actionscript.
grafxflow
Re: button to run script, pause, then run again ?
on Feb 24, 2007 at 5:40:00 pm
You could let the button carry out the action and disable it
button._enabled = false;
then have the last frame of your page-over animation activate the button again
button._enabled = true;
grafxflow
