XML and standalone Flash application
COW Forums : Adobe Flash
luthervondude
on Feb 20, 2007 at 1:19:09 pm
I am making a project that will store a couple thousand records. I want to store the data in an XML document, but I cannot figure out how to modify the data in the XML. The project will be a stand alone application so I cannot use asp.net. Any help would be greatly appreciated.
Robb.
Sher Ali
Re: XML and standalone Flash application
on Feb 20, 2007 at 2:06:13 pm
you can use
zinc
to store an retrieve data from access database file or deal with flat files like xml or txt files.
Sher Ali
http://www.webeyestudio.com
luthervondude
on Feb 20, 2007 at 2:24:14 pm
Zinc? I am not familiar with it. Could you post a URL please? Thank you.
Sher Ali
on Feb 20, 2007 at 2:40:09 pm
zinc is not a free software.
here is the link of the developer company:
http://www.multidmedia.com/
Sher Ali
luthervondude
on Feb 20, 2007 at 8:21:06 pm
After downloading Zinc, I don't see how I can modify an existing XML file, do you have a code sample? It would be much appreciated.
Robb
Sher Ali
on Feb 21, 2007 at 5:46:29 am
nop, but try to read the documentation a little, because zinc provides access to local file system, I have used access with zinc and flash for a projector application.
Sher Ali
