mouse position condition
COW Forums : Adobe Flash
Footbaggin
on Feb 2, 2007 at 9:56:59 am
I am trying to create a code that would apply a condition to the x value of the mouse cursor. Does anyone know a working code for the following concept...
If the mouse pointer x value is > 200, then mcClip will rotate 10.
This is the code I tried... it doesn't work though, and I have no other ideas.
onClipEvent (load) {
if(_root._xmouse > 200) {
this._rotation += 10;
any help will be greatly appreciated.
grafxflow
Re: mouse position condition
on Feb 7, 2007 at 12:50:39 am
Try
onClipEvent (enterFrame){
trace(_root._xmouse);
You can delete the 'trace(_root._xmouse);' line, it's just incase you choose the menu 'control/test movie' inside of flash. It will bring up a window showing the xposition of the mouse live.
Hope this helps.
grafxflow
grafx that flow!
