Flash strobing on Plasma display
COW Forums : Adobe Flash
John Rowe
on Jan 31, 2007 at 9:07:36 am
I'm outputting a 2560x1024 flash interactive split across two Panasonic Plasma screens (each plasma at 1280x1024 res) and I'm getting annoying strobing as the MovieClip objects animate across the screen.
When I try it on my two Dell 20" monitors it looks fine but on the plasmas it strobes noticably.
Any ideas on why the plasmas are doing this?
Anyone have experience/problems with displaying Flash on Plasmas?
Thanks very much, any help/thoughts greatly appreciated!
Re: Flash strobing on Plasma display
on Feb 2, 2007 at 7:05:54 pm
wow those are some large displays, can the PC driving them push that much through at once. What is the CPU and GPU on the playback PC?
What is the frame rate of the SWF?
What are you moving; bitmaps, vectors, text?
Are you tweening or using code?
Post back with more info
© 2018 All Rights Reserved
