external images
COW Forums : Adobe Flash
external images
on Jan 28, 2007 at 2:22:03 am
I have a sequence of about 100 JPEG images that I want to put on my flash website. However, the swf file size it way too big with all these images in the library. What would be the best way to get this sequence playing on the web? Do I have to load each file through actionscript frame by frame?
Thanks for your help!
here's the site (be patient)
Re: external images
on Jan 29, 2007 at 4:36:22 pm
Do you know if you're going to always show the images in the same order?
I might make an array of filenames at the start, and then run a loop on the array. This will involve repeating less code than coding each image.
© 2018 All Rights Reserved
