Capturing Simultaneous keystrokes
COW Forums : Adobe Flash
on Jan 22, 2007 at 8:12:45 pm
I'm having a problem trying to get flash to recognize 2 keystrokes at once.
An example is you're making a game where a character runs and shoots at the same time.
You hold down the right arrow key to move and tap the space bar to fire.
Well, so far I can't get flash to recognize that the spacebar is being pushed; it proceeds as though only the right arrow key is being pressed until it is released, then it will recognize the spacebar.
I'm using a modified sample of a key listener.
var keyListener:Object = new Object();
keyListener.onKeyDown = function() {
if (Key.isDown(Key.LEFT)) {
object_mc._x = Math.max(object_mc._x - distance, 0);
Can flash do what I'm asking it? Any ideas on how to make it happen?
Re: Capturing Simultaneous keystrokes
on Jan 25, 2007 at 8:54:58 pm
I'm curious about the part with "..."
The first thing that occurs to me is if you are doing the
} else
if (Key.isDown(Key.SPACE)) {
In which case you want to remove the "else."
© 2018 All Rights Reserved
