.flv resizing issue
COW Forums : Adobe Flash
Bryan Sykora
.flv resizing issue
on Jan 15, 2007 at 7:51:17 pm
I'm compressing a .flv for a customized player.
Screen is 240x135, and I'm compressing a 720x486 letterboxed vid, cropping top and bottom. Output file is 240x135.
When it plays back in the interface, I'm seeing this very annoying line directly in the center (horizontally) through the video (
The compressed video doesn't have this when playing in an .flv player, but shows up everytime in the flash interface. Seems to be some weird resizing issue once it's in the interface, but I checked both interface and video, and both are exactly 240x135.
Anyone have any ideas?
FYI: I'm compressing using Sorenson Squeeze, using On2 VP6 Pro codec.
Matt Klundt
Re: .flv resizing issue
on Jan 16, 2007 at 5:21:37 pm
Does the line disappear if you zoom in or out in the flash interface?
You could try specifically assigning the size through code (myVideo._width = 240; myVideo._height = 135) as sometimes the authoring program adds unnecessary decimals to objects on the stage.
Bryan Sykora
on Jan 16, 2007 at 5:28:31 pm
Just discovered actually that video is outputting at 240x134, and flash player is sizing it up, resulting in the line across the middle.
Anyone know if I'm limited to even pixel frame size? Can't get any compression software to let me create 240x135...
© 2018 All Rights Reserved
