flash and cue points
COW Forums : Adobe Flash
on Jan 15, 2007 at 6:35:35 pm
I am working on flash 8. I have encoded a video with all my cue points and the text to match. Once in flash I have gone through the correct order of setting this up within actions and the FLV content playback etc. On playback the video plays and you can navigate to each cue point I created, however for some reason my text does not appear as i wanted it to.
the code states :
**Error** Scene=Scene 1, layer=actions, frame=1:Line 60: The class or interface 'com.themakers.effects.BlurFader' could not be loaded.
var cfb:BlurFader = createClassObject(BlurFader, "cfb", 2, {dir: "in", duration: 2, target: tLabel});
can anybody shed any light on this 1 error? I know this is what is causing my text not to show!
thank you.
Sher Ali
Re: flash and cue points
on Jan 15, 2007 at 7:42:11 pm
yes, the error is very obvious. Actually you are loading an external actionscript class named
but due to some path issues it is not being load and giving you an error. The issue of path to the actionscript file which contains BlurFader class.
double check the path to the external files you are referencing.
Sher Ali
© 2018 All Rights Reserved
